dave3712
#1 Posted : Saturday, October 15, 2016 8:16:37 AM(UTC)
dave3712
i own a LG DLE5977B, that tripped my breakers a few times. it was very hot to the touch (back panel) when it was in normal drying cycle which uses medium heat. this happened a few times, i allowed it to cool each time prior to restarting after resetting the breaker. Now it is working and not getting as hot as it was, i am running it on high and it is not tripping breaker anymore. it feels warm but i dont think it is hot as it should be on high. i have check for blockages and found none. i would expect a thermostat or sensor might be at fault possibly, what parts should i check out?
ThatGuy
#2 Posted : Saturday, October 15, 2016 8:34:41 AM(UTC)
ThatGuy
I'd check the heating element to see if its partially burnt out or shorted to its shell.
LG 5301EL1001J Heater Assembly - AppliancePartsPros.com
Also check your venting.
WED4815EW1 Dryer overheating? (Dryer Repair)
by Guest 4/16/2024 12:21:03 PM(UTC)
Kenmore gas dryer overheating and shutting down in permanent press setting (Dryer Repair)
by Actonite 8/14/2022 4:57:32 PM(UTC)
Whirlpool dryer overheating, replaced thermostats (Dryer Repair)
by rastoma 10/18/2017 6:29:27 PM(UTC)
Kenmore Dryer Overheating and weak (Dryer Repair)
by Cardiaccat 9/3/2017 9:25:50 AM(UTC)
Dryer Overheating When Not Running (Dryer Repair)
by Chris McCain 4/5/2017 8:06:45 AM(UTC)
Maytag Dryer Overheating (Dryer Repair)
by atem2144 10/28/2016 12:34:41 PM(UTC)
Estate Dryer Overheating. I suspect hot air leaking from drum (Dryer Repair)
by Picklefall1 9/12/2016 8:13:23 PM(UTC)
Kenmore Dryer Overheating (Dryer Repair)
by atem2144 8/17/2016 1:41:31 PM(UTC)
by dadunn60 3/1/2016 9:43:04 AM(UTC)
by sfhutchi 2/28/2015 1:57:08 PM(UTC)
Whirlpool Dryer Overheating (Dryer Repair)
by TravisC 1/17/2015 11:13:36 AM(UTC)
by HawtDog 1/12/2015 1:59:21 PM(UTC)
Duet Dryer Overheating (Dryer Repair)
by Snarlybarley 11/20/2013 6:44:40 AM(UTC)
Dryer Overheating When Turned Off (Dryer Repair)
by Jeffshumaker 10/13/2013 4:27:05 PM(UTC)
Dryer overheating (Dryer Repair)
by jltuttl 8/30/2013 10:09:52 AM(UTC)
