BhamBigDaddyD
#1 Posted : Friday, October 14, 2016 9:45:56 AM(UTC)
BhamBigDaddyD
Our Maytag dryer will turn on and we hear a "click" indicating (I think) that the door safety latch has engaged. We hit the start button, but nothing happens. I read online that this is a common problem and it is typically the fuse. A quick check with my multimeter for continuity showed that the thermal fuse was bad. I replaced it with a brand new one (tested it for continuity first to be sure) and I am still getting the same results. I also replaced the thermistor since I was right there...still not getting anything. Any more ideas on what to check?
brobriffin
#2 Posted : Tuesday, October 18, 2016 9:24:48 AM(UTC)
brobriffin
Man
Check for continuity on the door latch switch.
Whirlpool WPW10318609 Switch-Dor - AppliancePartsPros.com
If it is good check to see if the drum belt is broken as there is a broken belt switch that will prevent the unit from starting as well.
Whirlpool 279782 Broken Belt Switch Kit - AppliancePartsPros.com
