2 Pages12>
LowlevelRebel
#1 Posted : Tuesday, September 20, 2016 8:44:23 PM(UTC)
LowlevelRebel
This evening I found my fridge had stopped working, and upon checking, the freezer as well. After removing all food from it, I found neither the fridge nor the freezer were blowing any air, cold or otherwise. There is a fan in the back that is running, and it appears to be the only thing making noise. I've attempted to include a picture of the fan in question. I shut down the unit, and unplugged it for about 20 minutes before restarting it, with no results. I vacuumed all the dust I could from beneath it, and am no longer sure how to proceed. Any insight at all would be appreciated. If it makes any difference, it has a water-dispenser, and ice-maker in the left (freezer) door. Those are not hooked up at the moment.
LowlevelRebel attached the following image(s):
LowlevelRebel
#2 Posted : Wednesday, September 21, 2016 6:00:15 AM(UTC)
LowlevelRebel
After leaving the unit on overnight, this morning I found new frost on the bottom half of the freezer's rear wall, and the fridge's rear wall feels *slightly* cooler. No change in the sound the unit is making, still no air blowing.
LowlevelRebel
#3 Posted : Thursday, September 29, 2016 4:25:52 PM(UTC)
LowlevelRebel
After shutting the freezer and fridge off and leaving it unplugged for a day, both worked again when I plugged it in and turned them back on. It worked properly for a week, and then the fridge started to warm, barely blowing any air at all. I bought a thermometer for each. The freezer is working as normal, but the fridge is holding at around 10'. Both were set at and left at maximum. As of this update, I have turned both down to see if there is any change. I'm left confused by one working while the other is not. Can anyone please offer any insight?
cbmserviceguy
#4 Posted : Friday, September 30, 2016 4:56:10 AM(UTC)
cbmserviceguy
Sounds like a defrost problem to me. Look at the back wall of the freezer. There is a panel there you can remove to expose the evaporator coil. Have a look and see if it's plugged up with frost. There is a fan back there as well that circulates air from the freezer to the fresh food side and then returns via ducts in the bottom. If any of those channels are blocked by frost, it won't cool and will show up first in the fresh food side. Take a look and see if you have a plugged evaporator or frosted over supply or return duct and make sure the evaporator fan is running and repost so we can determine the next step.
LowlevelRebel
#5 Posted : Sunday, October 9, 2016 9:53:18 PM(UTC)
LowlevelRebel
Thanks for your reply. I've been away, and the fridge has been off since the time of your reply. I intend to follow your kind advice and open up the rear of the freezer when I am home long-term in a week.
LowlevelRebel
#6 Posted : Saturday, October 22, 2016 11:47:49 AM(UTC)
LowlevelRebel
Can I expect to see the evaporator fan running constantly, or does it run on and off?
cbmserviceguy
#7 Posted : Monday, October 24, 2016 4:06:42 AM(UTC)
cbmserviceguy
It runs off and on based on cooling needs.
LowlevelRebel
#8 Posted : Tuesday, October 25, 2016 9:16:41 PM(UTC)
LowlevelRebel
This evening, I removed the panel at the back of my freezer and found ice as you predicted. The fan pictured is running and blowing air upwards. It's the only fan visible at the time of this posting. I can see where the air enters the fridge half of the unit, but not where it exits the area behind the freezer. What do you recommend from here?005.jpg
cbmserviceguy
#9 Posted : Wednesday, October 26, 2016 5:15:05 AM(UTC)
cbmserviceguy
What you have is a defrost issue. The first thing to do is thaw it just enough to check the ohms on the defrost limit and heater. Be careful not to thaw the limit disc out, just enough to get at the wires. Check the ohms thru the limit, then disconnect and check ohms thru the heater. Post what you come up with. If they both check out ok, you will need a new electronic defrost timer. Below are all parts for reference.
http://commercial.******...amp;pathTaken=partSearch
ThatGuy
#10 Posted : Wednesday, October 26, 2016 9:15:52 AM(UTC)
ThatGuy
2 Pages12>
