2 Pages<12
saiber77
#11 Posted : Monday, September 26, 2016 9:51:48 AM(UTC)
saiber77
Apparently cheap and easy was too much to ask for lol, back to the drawing board. Tested the noise filter and same result, Piezoelectric speaker on the user interface board makes t-click sounds and then no result from pressing power/start/stop etc, no lights. Pulled both the UI board and the CCU board, did a full visual inspection and no burnt traces, no popped caps, no blackened or arced components. A little bit of white dust inside due to the CCU mount clips falling apart and apparently bouncing around in the machine or rubbing against the drum. Going to test continuity of the fuses and clean the connectors and board with rubbing alcohol. Any other tips on testing the board components of either the UI or the CCU?
Oh and how long do I have to return the Noise Filter if it turns out that it doesn't need replacing? Thanks in advance.
brobriffin
#12 Posted : Monday, September 26, 2016 10:18:42 AM(UTC)
brobriffin
Man
AppliancePartsPros.com - 365-Day Hassle Free Return Policy:
Unlike our competitors that only offer 30 or even 15 days, we offer 365 days to return a part and we make the process very simple and truly hassle free!
If you are not 100% satisfied with your purchase, we will be happy to accept a return for a full refund. While our competitors have strict rules about returning electrical, gas, or special order parts, we let you return any part you buy from us for any reason!
We'll even pay for return shipping if the return is a result of our error. Just let us know and we'll provide you with a prepaid shipping label. Please make sure to use the label, as no refunds will be issued for any shipping cost if you decide not to use our shipping label.
You may return your purchase for up to 365 days from the purchase date.
You may return any part purchased from us, including electrical, gas, or special order parts.
Full refund means price paid plus any applicable tax excluding original shipping charge.
Once your return is received and processed by our warehouse staff (usually within 72 hours of receipt), we will credit your credit card or original method of payment within a few days. Please note that depending on your credit card company, it may take additional 2-10 business days after your credit is applied for it to post to your account.
To return an item, log in to your account and click on "returns".
Have questions? We&#8217;re here to help you!
&#8232;Call us toll free at 1-877-477-7278 or chat with us live.
saiber77
#13 Posted : Monday, September 26, 2016 12:55:46 PM(UTC)
saiber77
Ok, thanks brobriffin. The scripted reply helps on the returns question. I take it you are deliberating my other questions? :D
brobriffin
#14 Posted : Monday, September 26, 2016 7:01:18 PM(UTC)
brobriffin
Man
No other data or references on end user or tech level testing of components on MCU, CCU or UI found. Sorry ¿Planned obsolescence?
All references point to replacement rather than repair. I understand the why, as a service tech receiving so much per hour it's more cost effective to replace rather than seek out a bad diode or resistor, or determine if a solder joint needs to be reflowed.
Sorry but unless you are well versed in computer board circuits and pathways I would try a replacement CCU. A google search may result in a lower price re-manufactured unit.
2 Pages<12
