Mike Sasser
#1 Posted : 8 years ago
Mike Sasser
I checked water pressure to inlet valve all good,but no water from valve to ice maker. Unplugged power source,unplugged valve and did a continuity test on valve. Digital meter read 193 manufacturer says should be between 500 and 1500, does that mean the inlet valve is bad?
cbmserviceguy
#2 Posted : 8 years ago
cbmserviceguy
I would say it's at the least very suspect. Have you forced a harvest cycle and checked for voltage at the valve?
Mike Sasser
#3 Posted : 8 years ago
Mike Sasser
No,how do you force a cycle?
cbmserviceguy
#4 Posted : 8 years ago
cbmserviceguy
Depends on the age. Typically W/P you pop the front cover off the ice maker and put a jumper wire between T and H. After it turns for a bit, pull the wire and it should keep going. Go around back and watch the meter for a few second flash of 120vac. Get the meter set up and connected to the valve plug before you jump it.
Ice maker not getting water (Refrigerator & Freezer Repair)
by GLP 8 years ago
by awashko 11 years ago
ice maker not getting water (Refrigerator & Freezer Repair)
by jmr82 12 years ago
by markplee@comcast.net 13 years ago
KitchenAid Ice Maker Not Getting Water (Refrigerator & Freezer Repair)
by Steingraber 13 years ago
by redgtfour 13 years ago
ge monogram - ice maker not getting water (Refrigerator & Freezer Repair)
by jmeurer 13 years ago
Ice Maker not getting water (Refrigerator & Freezer Repair)
by garye 15 years ago
Ice Maker Not getting water (Refrigerator & Freezer Repair)
by headtester 16 years ago
Whirpool ice maker not getting water (Refrigerator & Freezer Repair)
by bjustice 16 years ago
by bwseabee@yahoo.com 17 years ago
Frigidaire Ice Maker not getting water & not working (Refrigerator & Freezer Repair)
by Salpal 17 years ago
by DBBromberg1 17 years ago
Ice maker not getting water. (Refrigerator & Freezer Repair)
by brandon58 18 years ago
