Groups: Joined: 12/1/2008(UTC) Posts: 0
Hi. The fast track service manual for the Samsung dryer model # DV219AGW/XAA will be sent. The gas valve is Part number: AP3845027
. The bubble leak detector is Part number: AP3766089
. Good luck. Thank You. Originally Posted by: Replacement Where can I find a service manual that shows how to get to the gas valve in the dryer?
The noise may be the drum seam .
