Joined: 9/1/2016(UTC) Posts: 2 ![United States United States](/Content/images/flags/US.png) Location: UT
I have a Kenmore washer that is not doing anything, will not come on for any cycles. I took a look down below and I see burn marks on the connector to the motor switch. I had a tech come visit and he confirmed my issue, but did not have the wire harness for this washer. I read in another forum post about trimming recapping and then reinserting the wire with cap into the connector and done. I know the part number from Sears if I needed to replace the connector itself is WP62505. But for the cap I would need to fit this or the old one, can someone lead me to what that would be? I would replace the whole wiring harness, ($45 to $70), is much cheaper than a new washer, but I cannot find the wiring harness anywhere. Your help is much appreciated.
Image of connector with arc scorches. Fred_E attached the following image(s):
