Hello, I have a kenmore 600 series dryer that the timer won't go past the 30 minute mark. The dryer gets hot but timer stops at 30 minutes. Should I replace the timer or could their be a bigger problem?
Joined: 6/13/2014(UTC) Posts: 781 ![Man Man](/Themes/yafvision/male.gif) ![United States United States](/Content/images/flags/US.png) Was thanked: 1 time(s) in 1 post(s)
If this happens whether you set the timer for only 40 minutes or the maximum time setting then I suspect the plastic gear inside the timer may be bad. Will the timer run a complete cycle in the other settings? Will it complete the cycle if you turn it a bit past thirty minutes manually? Whirlpool WP3976576 Timer - AppliancePartsPros.com
Originally Posted by: brobriffin ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) If this happens whether you set the timer for only 40 minutes or the maximum time setting then I suspect the plastic gear inside the timer may be bad. Will the timer run a complete cycle in the other settings? Will it complete the cycle if you turn it a bit past thirty minutes manually? Whirlpool WP3976576 Timer - AppliancePartsPros.com Yes the dryer will complete the cycle but the knob won't go past 30 minutes.
Originally Posted by: brobriffin ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Thank you very much!
