have two problems with my neptune. when it spins it makes a loud shrill noise. Bearing? Also, it fills with water after a couple days without use. once it even blew the door open and flooded the laundry room! any suggestions?
Joined: 6/13/2014(UTC) Posts: 781 Was thanked: 1 time(s) in 1 post(s)
Can you give us the model / serial #s The sound can be a number of things from bearings to belt to support arm. The water issue sounds like you need to replace the water valve assembly. More details are available with model number.
model # MAH5500BWW S/n A9054433EG
