I watched the video and ordered the suspension rod kit from APP. I will let you know if it helped when I get them installed. Thank you for your assistance.
Joined: 6/13/2014(UTC) Posts: 781 Was thanked: 1 time(s) in 1 post(s)
That's great Johnart, I really think that will solve the issue. Please reply and let us know the outcome. Thanks for using our forum and shopping APP.
IT WORKED!! I got the parts from APP in a very timely manner. It was an easy install once I figured it out. (I should have watched a video) We have done several loads both large and small loads and have had no issues. Thank you for your assistance!
Originally Posted by: brobriffin When I lift my washer, it does look like oil spatter all over. I have a MVWB450WQ2, which my wife absolutely hates. I am getting the uL code at the 12 minute left mark. I have tested the suspension and they seem fine. The allen nut on the rotor seemed to be tight at well. The washer has been running loud, as if I had a freight train in my basement. Ideas? From what I am reading, it seems like the freight train in probably the bearings needing to be replaced. Correct?
