Majeci
#1 Posted : Thursday, July 7, 2016 11:37:56 AM(UTC)
Majeci
Hi there--
We have a Whirlpool top loading washing machine that will only add hot water. I did some research and have done the following so far:
1) Checked the water supply. Plenty of hot and cold water, plenty of water pressure.
2) Replaced the water intake valve with a new one. This did not help.
3) Switched hoses, which made the machine only add cold water, and not hot water.
4) Tested the water temperature switch with a multimeter (I don't have a lot of experience with this, but it read 120 volts), so I don't think it's faulty.
What are my next steps? Hopefully there's something I can do short of calling a repairman or buying a new washer...
Thanks in advance.
-Mike
brobriffin
#2 Posted : Thursday, July 7, 2016 12:06:45 PM(UTC)
brobriffin
Man
In your trouble shooting steps I imagine you turn the water temp select to different positions. You should be able to do this while filling and see when selecting hot , warm & cold if the valves open and close. It sounds to me that the water temp switch while showing 120 v is not opening the cold valve. You can replace with Whirlpool WP8577786 Swtch-Temp - AppliancePartsPros.com if faulty.
