Hello
I have a 6 year old dryer that gets lots of use. I need a technician that can help me with a very difficult problem. The initial problem was the wrong orfices in my gas valve, I have a propane dryer that had natural gas orfices and ultimately after putting in the right orfices and changes the high limit thermostat which was burned, the dryer worked fine. Now it works intermittently. It will do a few loads fine and than the next few will be wet. I've changed the gas valve and coils which did not work. I changed the main board which did not work. I've tested all the heating parts with an ohms meter and they seem to be giving proper readings. The glow igniter always comes on but the flame does not always comes out when cycling through. I am at my wits end but would like to try a few more parts before I give up!
Thanks...Dave
