DigumTodd
#1 Posted : Sunday, March 2, 2014 10:20:16 AM(UTC)
DigumTodd
I have had a lot of problems with this washer and these forums have helped a lot. Butt I'm stumped on a new problem. It will go through the cycles just fine but once it says done it starts filling and going through them all over again. It will only stop if I manually stop it. Cycle repeat
DigumTodd
#2 Posted : Sunday, March 2, 2014 10:27:53 AM(UTC)
DigumTodd
Just a little history. The discharge pump got bound up so it wasn't draining, I got pissed and ripped the lid open breaking the lid switch. I freed up the pump, replaced the switch, and now this. Also the water level switch now has a very stiff/ noisy movement.
mmona
#3 Posted : Sunday, October 5, 2014 8:45:41 AM(UTC)
mmona
Hey,
I have the same problem of cycle repetition. What should I do???? the machine is only two months out of the one year factory warranty :(
fishingjeh
#4 Posted : Monday, June 13, 2016 11:14:59 AM(UTC)
fishingjeh
Originally Posted by: mmona Go to Quoted Post
Hey,
Is there a solution to this as having the same issue and not sure if the control board will fix this issue. Everything seems to work fine it just repeats cycle after it has finished with the cycle was on.
