tomkouch
#1 Posted : Friday, April 8, 2016 12:36:28 PM(UTC)
tomkouch
I got an F30 fault message and saw that I needed to replace part # 316217002 and the proper replacement part was #6475657. The part came and I replaced it today, and I'm still getting the same fault message, and I cannot preheat the oven or set the clock and the top burners wouldn't work unless I leave the breakers off for 10 minutes or so. I'm not sure what to do next. Any help would be appreciated. Thanks, tom.
Alexkourelis
#2 Posted : Friday, April 8, 2016 2:05:58 PM(UTC)
Alexkourelis
Is this gas or electric?
tomkouch
#3 Posted : Friday, April 8, 2016 3:00:28 PM(UTC)
tomkouch
this is an electric countertop insert with oven. I had included the info in the headings. Evidently it didn't flow down into the body of the message. It is a Frigidaire model PLES389ECC.
Alexkourelis
#4 Posted : Friday, April 8, 2016 3:08:22 PM(UTC)
Alexkourelis
I figured by the complaint. Im willing to bet if u check the outlet u only have 120v +/-10% . U should have 240v +/- 10%
So 210v ish --250v ish is goona be what u need.
tomkouch
#5 Posted : Friday, April 8, 2016 3:43:03 PM(UTC)
tomkouch
Nope-that wasn't it. I've got full power.
Alexkourelis
#6 Posted : Friday, April 8, 2016 3:54:00 PM(UTC)
Alexkourelis
If u truly checked ur power then ur problem is ur control. Alot of ppl dnt because they think its worked for 5 years thats not it but i get at least 2 a week that need a new line ran. Same with dryers. Also u can have a weak breaker. So if u replace the control and still have an issue its the power.
tomkouch
#7 Posted : Sunday, April 10, 2016 1:00:26 PM(UTC)
tomkouch
Do you mean the control setup on the front of the stove with the knobs to turn on the burners or the circuit board in the back of the stove? I have seen both referred to as the control panel.
Alexkourelis
#8 Posted : Sunday, April 10, 2016 3:58:03 PM(UTC)
Alexkourelis
Ur main control not touchpad/membrane un less u notice one of the keys not responding
