brokenge
#1 Posted : 9 years ago
brokenge
My potable dishwasher, GE model gsc3507p00ww, was taken apart and the pump and motor assemble was removed to replace the lower spray arm support. After reassembling, the dishwasher will not drain. the drain solenoid lever is engaging. There is no water making it to any part of the drain hose or chamber hose. There is no valve flapper on the chamber collection on this model. The dishwasher sounds as it should and the drain solenoid lever is engaging. I used a YouTube vid. https://www.youtube.com/watch?v=fnrqQxkgbOg as the motor looks the same as mine. I have cleaned all the parts and hoses. I can drain the dishwasher by hand depressing the drain solenoid lever while the drain hose is detached.
Joe / APP Team
#2 Posted : 9 years ago
Joe / APP Team
Originally Posted by: brokenge Go to Quoted Post
My portable dishwasher, GE model gsc3507p00ww, was taken apart and the pump and motor assemble was removed to replace the lower spray arm support. After reassembling, the dishwasher will not drain. the drain solenoid lever is engaging. There is no water making it to any part of the drain hose or chamber hose. There is no valve flapper on the chamber collection on this model. The dishwasher sounds as it should and the drain solenoid lever is engaging. I used a YouTube vid. https://www.youtube.com/watch?v=fnrqQxkgbOg as the motor looks the same as mine. I have cleaned all the parts and hoses. I can drain the dishwasher by hand depressing the drain solenoid lever while the drain hose is detached.
Brokrenge, If you're sure the drain hose isn't kinked, clogged or obstructed, then you'll need to dismantle the drain solenoid assembly, use a small flat blade screw driver and remove the valve actuator arm Part number: AP4347034
You'll probably find that it is "rounded out" or cracked and is "slipping' on the drain flapper shaft.
Joe / APP Team
#3 Posted : 9 years ago
Joe / APP Team
Whirlpool Dishwasher Won't Drain Completely, I hear Pump Running... (Dishwasher Repair)
by Guest 3 years ago
Bosch SHU33 dishwasher won't drain when hot just after a wash (Dishwasher Repair)
by Guest 4 years ago
Bosch dishwasher won't drain, begins cycle, then stops - FIXED (Dishwasher Repair)
by mabradbury 6 years ago
Bosch dishwasher won't drain completely (Dishwasher Repair)
by nathaniel.hoffman@gmail.com 6 years ago
GE dishwasher won't drain after last rinse cycle (Dishwasher Repair)
by autotech1 7 years ago
Dishwasher won't drain (Dishwasher Repair)
by Drummabouy 8 years ago
Dishwasher Won't Drain or Run Cleaning Cycle (Dishwasher Repair)
by Katie L 9 years ago
Bosch Dishwasher won't drain and goes directly to "Clean" Light (Dishwasher Repair)
by ed3120 9 years ago
Frigidaire dishwasher won't drain (Dishwasher Repair)
by kohanz 9 years ago
Dishwasher won't drain! (Dishwasher Repair)
by Crafter_Man 9 years ago
GE Dishwasher won't drain all way (Dishwasher Repair)
by AnthonyJS02 10 years ago
by av0612 11 years ago
Frigidaire Gallery Series Dishwasher won't drain fully after disposal replacement (Dishwasher Repair)
by wicked94pgt 11 years ago
GE Dishwasher won't drain (Dishwasher Repair)
by crabbygardener 11 years ago
Dishwasher won't drain all the way (Dishwasher Repair)
by jennie_49031 11 years ago
