lenrosenberg
#1 Posted : Sunday, October 19, 2008 6:27:36 PM(UTC)
lenrosenberg
Here's the problem with my GE TFF-22D, side-by-side unit: (1) The top of the freezer does not freeze, while the bottom part does. (2) The top of the refrigerator is cool, not cold, but it gets a bit colder towards the bottom of the refrigerator. My diagnosis: (1) the defrost timer goes through its cycle OK (2) I tried unpluging and repluging to reset the unit, but no change. (3) Alas! the evaporator does not come on at all. Is this my problem? Do I need a new evaporator fan motor or is something else keeping it from coming on? If the problem is solely the fan motor, how do I test it just to be sure? Thanks.
richappy
#2 Posted : Monday, October 20, 2008 1:24:12 AM(UTC)
richappy
Sounds like a bad compressor or a refrigerant leak. Measure the back wall freezer temperature and post.
lenrosenberg
#3 Posted : Wednesday, May 20, 2009 3:26:56 PM(UTC)
lenrosenberg
You may be wondering why I took so long to respond. Well, (1) it's a refrigerator in the garage and it's hard to get accurate readings and (2) I finally got my temperature gun fixed. So here goes: I'm going to give you a set of readings, first is the freezer in four increments from bottom to top: minus 6, 15, 31, 54 and here is the refrigerator section also from bottom (drawers) to top: 41, 52, 60, 65. The fan in the freezer has not gone on. Thanks.
woodchuckie
#4 Posted : Wednesday, May 20, 2009 4:04:20 PM(UTC)
woodchuckie
lenrosenberg
#5 Posted : Tuesday, May 26, 2009 5:06:06 PM(UTC)
lenrosenberg
Thank you. The problem was the evaporator fan motor. A continuity check on the motor showed it was dead. $22 and 10 minutes and I was back in the chill of things. You guys did it!!! :)
Best Wishes,
Len
GSS23HMHBCES - GE side-by-side (Refrigerator & Freezer Repair)
by rochacha 4/19/2023 12:04:59 PM(UTC)
GE side-by-side water/ice dispenser stops working during defrost (Refrigerator & Freezer Repair)
by pvsherman 12/18/2022 11:23:17 AM(UTC)
GE Side-by-Side freezer door dispenser leaking (ESS25LRBSS) (Refrigerator & Freezer Repair)
by dhunsing 9/28/2022 12:59:56 PM(UTC)
GE side-by-side running constantly? (Refrigerator & Freezer Repair)
by RCorley00 9/17/2014 9:41:06 AM(UTC)
GE Side-by-side Fridge stopped getting cold (Refrigerator & Freezer Repair)
by pflon 3/9/2014 3:37:58 PM(UTC)
changing motherboard on ge side-by-side (Refrigerator & Freezer Repair)
by av8or 9/10/2013 2:19:18 PM(UTC)
GE side-by-side not making ice, slow water dispensing (Refrigerator & Freezer Repair)
by sklim1 2/5/2013 8:20:30 PM(UTC)
GE Side-by-Side Water Drip (Refrigerator & Freezer Repair)
by jladd 7/30/2012 10:28:17 AM(UTC)
GE side-by-side evap. coils freezing, fridge freezing at bottom and not cold at top (Refrigerator & Freezer Repair)
by jttaylor 1/23/2012 11:24:01 AM(UTC)
GE side-by-side ice-maker leak into freezer; ice dispenser not working (Refrigerator & Freezer Repair)
by SSWeinland 4/11/2011 8:40:31 AM(UTC)
ge side-by-side refrigerator (Refrigerator & Freezer Repair)
by Gennifer916 7/16/2010 11:22:33 AM(UTC)
GE Side-by-side freezer door hinge replacement (Refrigerator & Freezer Repair)
by kinsman 3/25/2010 8:18:50 AM(UTC)
GE Side-by-side Cooling Problem (Refrigerator & Freezer Repair)
by hansen.gk 3/1/2010 1:59:12 PM(UTC)
Evaporator Freezing GE Side-by-Side (Refrigerator & Freezer Repair)
by tforeman 2/23/2010 10:19:11 AM(UTC)
Ge side-by-side fridge too warm (Refrigerator & Freezer Repair)
by mcl143 11/10/2009 4:52:39 AM(UTC)
