My GE Profile Oven - is not heating past 100. The broiler however works. What could be the problem? Several months ago we replaced the igniter - part number 410WB2X9154. The problem is back.
Hi. I'm having my own adventures with an electric GE Profile.
The things I can think of that could be causing your issue are the sensor/thermostat, the relay, or the relay/daughter board assembly.
All of these are actually pretty easy to replace yourself. The sensor/thermostat is probably the most likely, and the least expensive. So I'd suggest starting there and if that doesn't solve the problem, try the relay next.
