randufull
#1 Posted : Monday, July 11, 2011 3:24:28 AM(UTC)
randufull
My GE front load washer wont agitate but turns afew times very slow then
the water fills and it turns afew more time as if to start washing but doent
and the water drains without washing and it wont go into a spin cycle
after all that it pauses with alot of time still left on the timer. I cleaned the
trap but that didnt do it, plz help me ?:confused:
sidfink43
#2 Posted : Tuesday, July 12, 2011 5:40:07 PM(UTC)
sidfink43
Ge does not release tech info, so about the best I can do is to have you look inside the service panel and see if you can find some tech notes that will let you put it into a diagnostic mode.
maestro1928
#3 Posted : Thursday, February 11, 2016 6:02:14 AM(UTC)
maestro1928
washer will only spin in one direction.
sidfink43
#4 Posted : Thursday, February 11, 2016 12:11:47 PM(UTC)
sidfink43
Hi Maestro
If you will start a new thread and include your model number and a more detailed description of the problem someone may be able to help. I am no longer responding to posts on this Forum.
Joe / APP Team
#5 Posted : Friday, February 12, 2016 9:09:04 AM(UTC)
Joe / APP Team
Maestro, It's most likely going to be a problem in the motor control unit Part number: AP4421584
. Use the attached tech data sheet and review the error codes and perform the recommended tests. You'll have it diagnosed and repaired in no time.
File Attachment(s):
31-16559-1 (1).PDF (273kb) downloaded 9 time(s).
GE Front Load Washer Not Agitating or Spinning (Washer Repair)
by mghump 12/16/2013 6:13:15 AM(UTC)
