shffru123
#1 Posted : Thursday, February 11, 2016 3:41:59 AM(UTC)
shffru123
why is my door locked and why do I have a code F21
Joe / APP Team
#2 Posted : Thursday, February 11, 2016 12:00:01 PM(UTC)
Joe / APP Team
shffru, The F21 error code indicates a "long drain time" If the washer doesn't drain and the pressure switch does't reset to empty, the door wont unlock.
check and make sure the water level in the tub is below the door opening, unplug the power cord, remove the lower access panel(you should find the tech sheet attached to the panel) reach up between the front panel and the front of the tub, you should feel the manual release plunger, pull down on the plunger, this will unlock the door. You can then check the drain pump and hoses for clogs, debris, etc. You can also use the tech sheet to review the error codes and run the diagnostics service mode.
Oven Door Locked - No Power (Oven Repair (including Ranges and Cooktops))
by Nothing Finer 10/26/2020 3:33:54 PM(UTC)
Oven fan won’t stop/door locked/ F3 error (Oven Repair (including Ranges and Cooktops))
by Lizete 10/9/2020 7:53:38 AM(UTC)
Maytag Neptune (Front Loading) Washer Door Locked (Washer Repair)
by frjosephklee 5/4/2020 9:03:35 AM(UTC)
Kitchenaid wall oven door locked (Oven Repair (including Ranges and Cooktops))
by mdawley 3/6/2020 9:40:01 AM(UTC)
Whirlpool Wall Oven Door Locked and No Power (Oven Repair (including Ranges and Cooktops))
by sunia 11/14/2019 7:10:53 AM(UTC)
whirlpool front load won't run door locked won't open. (Washer Repair)
by bob67 12/6/2018 3:54:59 PM(UTC)
Whirlpool Double Wall Oven Dead after Self Clean - Door Locked (Oven Repair (including Ranges and Cooktops))
by cmartin27 1/19/2018 1:24:46 PM(UTC)
Whirlpool Accubake Double Oven Lower Oven Door Locked (Oven Repair (including Ranges and Cooktops))
by Malexi 6/2/2017 9:46:25 AM(UTC)
Turned on with water off to washer. Now door locked. (Washer Repair)
by Ramfan64 8/7/2016 9:47:40 PM(UTC)
F90 Error - Door Locked (Oven Repair (including Ranges and Cooktops))
by Tylan 12/12/2015 3:39:59 AM(UTC)
Door locked and stuck on drain cycle (Washer Repair)
by Brian blum 5/22/2015 8:28:23 PM(UTC)
ge double oven door locked (Oven Repair (including Ranges and Cooktops))
by jswim788 1/31/2015 11:30:12 AM(UTC)
door locked light on, no controls accessible (Washer Repair)
by SteveDB 1/19/2014 1:15:50 PM(UTC)
Frigidaire Professional Series Dual Oven Electric Range - Door Locked Won't Open (Oven Repair (including Ranges and Cooktops))
by D0nCap0 12/26/2013 2:40:40 AM(UTC)
Bosch Nexxt Premium - Flashing Lights and door locked (Washer Repair)
by PaulMullen 11/21/2013 7:20:06 PM(UTC)
