My dishwasher works fine. Dishes are clean, everything drains out, cycle completes. But when the water comes in to fill, it makes a very loud pulsating noise. The first time, I tried powering the whole machine off. It was completely off and the noise was still going until I turned the water supply off. So now when the noise starts up, we turn the water supply all the way off, immediately the noise stops and immediately we turn the water back on and voila, no noise. It does this about 3 times each cycle. We disassembled the intake valve assembly last night and cleaned out all the buildup and put it back. The noise has lessened but still very loud. Do you think that sounds like we need a new inlet valve assembly? Happens at the beginning of the wash and again at cycle 43 and 46. Model: SHE44C06UC/43 (Anyone know what happens at those particular cycles?) Video of the noise: https://www.youtube.com/watch?v=JLm3dQ_gJkE
