needhelp22
#1 Posted : Monday, January 11, 2016 6:45:33 AM(UTC)
needhelp22
Having issue with my gas dryer that will not start.
I try to turn it on a few times and each time has a different result.
1st test - Press the start button and it worked. (I stopped it after a few minutes, not sure how long it will run)
2nd test - 1 minute later from the 1st try. Makes a sound but does not work.
3rd test - Open the front cover. Press start button (does not work, unless I manually spin) the drum. Then it works. Flame doesn't stay on. Smelled burnt.
4th test - makes buzzing sound. Even after trying to manually spin it. It does not work.
5th test - no sound or working (the 5 test took between 15-25 minute period)
The next day. Tried again. Does not work on 1st test. But does work if I manually spin the drum. But stopped after a minute.
Any idea what is broken?
sidfink43
#2 Posted : Tuesday, January 12, 2016 5:44:45 PM(UTC)
sidfink43
This sounds very much like the motor is failing and given the age of the machine I suggest you replace. It will cost a little more than a DIY repair but you will have a new model under warranty that will serve you for years to come.
Maytag Ensignia Gas Dryer will not start. (Dryer Repair)
by MRWHO 8/17/2012 6:00:48 PM(UTC)
whirlpool gas dryer will not start (Dryer Repair)
by dmicare 9/19/2007 3:31:08 PM(UTC)
