DJ Chaffers
#1 Posted : Saturday, January 2, 2016 6:13:21 PM(UTC)
DJ Chaffers
Pots & Pan light flashing, dishwasher will not run. Turned off breaker, let sit for 10 minutes, turned breaker back on, still the same.. tried the Normal/Heated Dry/Normal Heated Dry reset sequence and still nothing..
Checked the filter it's clean.. what can be wrong? How can it be reset? was working great until New Years Eve..
#2 Posted : Sunday, January 3, 2016 2:41:54 AM(UTC)
Parts for Whirlpool GU2400XTPS3 Dishwasher - AppliancePartsPros.com
Could be a stuck key.
Unplug the unit and check the control panel/keypad with a meter. See the tech sheet.
If OK then odds are tthat the control board is bad.
