mbwdmd
#1 Posted : Thursday, January 17, 2013 5:27:01 PM(UTC)
mbwdmd
I want to temporarily disable the interior LED light in GE Profile french door
refrigeratior when opening doors. Light switch is by left door but activates when either door is opened. Taping it down has no effect.
#2 Posted : Friday, January 18, 2013 8:25:32 PM(UTC)
Why do you want to do it?
mbwdmd
#3 Posted : Saturday, January 19, 2013 8:04:01 AM(UTC)
mbwdmd
religious reason-sabbath light
#4 Posted : Monday, January 21, 2013 6:19:11 PM(UTC)
It's not easy because this light operates by a separate special control board. I can give you some instructions but it can damage the refrigerator controls.
zux85
#5 Posted : Tuesday, December 22, 2015 10:42:39 AM(UTC)
zux85
I know this is an old post, but it fits my issue exactly.
I need a way to disable the lights so that the interior lights dont go on when the door is opened.
An alternative would be to remove the light bulbs completely (assuming that is safe to do)
#6 Posted : Wednesday, December 23, 2015 1:27:51 AM(UTC)
I would just loosen the bulbs in the sockets.
zux85
#7 Posted : Wednesday, December 23, 2015 7:28:00 AM(UTC)
zux85
Thanks. it doesnt seem so simple.
there is a plastic cover which pops off.
underneath that is circuit board of sorts, with the LED bulbs built in, and a screw holding it in.
I took out the screw and the board is connected with 2 wires.
#8 Posted : Wednesday, December 23, 2015 11:00:11 AM(UTC)
I cannot tell you where to disconnect it as I do not have access to GE tech data.
If there is enough slack you could unplug the unit and cut the wire/s and then reconnect them later with a couple small wire nuts. You should only have to cut one of them.
Guest (10)
