Hello -- just replaced the cold water valve (it was leaking) with a new one direct from Bosch. Machine ran 6 or so loads just fine. But on PP cycle, it threw a F:17 code. I know it means water supply issues- I checked the hose and water supply and the inlet filter, and all are fine.
What would cause it to throw random F:17 codes??
More info after running it for another month: 1) if I run it on Cotton at any water temp, it works fine- no code. 2) if I run it on Cotton with an Extra Rinse selected, it will throw a F:17 code. 3) if I run it on Permanent Press, it will throw a F:17 code.
Any ideas on whats causing this?
