atp160
#1 Posted : Tuesday, November 17, 2015 6:03:25 PM(UTC)
atp160
Hello,
Have a Kenmore Elite washing machine:
HE3t
Model: 110.42924 200
Serial #: CSP 2304181
Type: 199-AKP702/BT
Only works on the delicate cycle. Could it be the,
Washer User Interface Board part# 8181699? or the Washer Electronic Control Board part # 8181692 or 8181899 or 8181980 with a substitution part # 285924?
Thank you for any help,
Respectfully,
Fred Tolerico
sidfink43
#2 Posted : Thursday, November 19, 2015 4:37:28 AM(UTC)
sidfink43
This is a Whirlpool Duet sold under the Kenmore brand name. It is a great washer but when it malfunctions even Whirlpool factory techs have trouble diagnosing the problem.
Under the top lid or inside the lower service panel there should be tech notes which will tell you how to put it into diagnostic mode and generate error codes. See if you can do that, but understand that in the end you may have to replace parts on spec, which is how many Whirlpool techs diagnose the issues on these models.
I would first start with the main control board. That is likely your problem and if you buy the part from this site and it does not fix the problem you can return it.
