trshannon
#1 Posted : 9 years ago
trshannon
Need to replace cold control part number ARB2117AS says discontinued nice fridge does thi mean i have to trash it for a $50.00 part
#2 Posted : 9 years ago
I would take it to a local parts supply house and they may have one that will work.
Try to get one with a capillary tube that is about the same length as the end of the capillary must be placed in the same position as the original.
You will probably have to jiggery pokery the mounting of it and maybe how you adjust it. But then how often do you need to adjust a fridge temperature so it should not cause a hassle.
The freezer should be 0 to 3 degrees F and the fresh food in the 36 to 38 range.
It may take you a couple days to get it set correctly.
trshannon
#3 Posted : 9 years ago
trshannon
I managed to get a replacement part. It looks like there is a long probe type wire attached to it. Where does thie go? initially nit looked like a couple of screws to remove and replace. Do I need to do some forensics to attach this wire type probe throught the fridge?
#4 Posted : 9 years ago
Take a look in section 5 of the parts.
I am confuse by your question as the one in the unit shouls also have a capillary tube, see below
Part number: AP4128378
trshannon
#5 Posted : 9 years ago
trshannon
So hopefully when I remove the old part there will be a capillary tube in the unit (the fridge) so I can simply slide the probe wire through it and it will navigate itself to the proper position?
Looking for discontinued part (Heating, Ventilation, and Air Conditioning (HVAC))
by Catherine57 4 years ago
Kenmore Elite Discontinued Part (Appliance Parts)
by rserra 4 years ago
looking for discontinued part wr17x6456 (Refrigerator & Freezer Repair)
by baritone44 13 years ago
Replacement part for discontinued part #9741559 (Dishwasher Repair)
by James F Morin 16 years ago
looking for replacement for discontinued part (Refrigerator & Freezer Repair)
by Jane Barber 16 years ago
replacement for discontinued part (Dishwasher Repair)
by rob kotler 16 years ago
Discontinued part needed (Microwave Repair)
by concierge 16 years ago
Replace Control Board for discontinued part (Dishwasher Repair)
by kmunro 16 years ago
Finding discontinued part - lens, indicator light (Oven Repair (including Ranges and Cooktops))
by decarteret 16 years ago
replacement thermostat discontinued part (Oven Repair (including Ranges and Cooktops))
by lctalbots 17 years ago
