The dryer heats up normally for the first 5-10 minutes, then cuts out and tries to dry on cool air. Start/stop doesn't fix, but resetting the cycle on the panel usually - but not always - does. However it still cuts out again after a short while. The heat won't come back on by itself during the cycle. Bad temperature cutout switch or thermostat? Bad control board? Your thoughts are appreciated
The number given does not come up as a Model Number. When I search it it comes up as a control panel. Please check it. |
THIS FORUM IS DEAD!!!!!!! |
