whovian2015
#1 Posted : Wednesday, September 30, 2015 2:56:35 PM(UTC)
whovian2015
My GE top load washer won't spin or agitate. I have checked/realigned the dial, lifted the lid 6 times in 12 seconds, checked the load tube and the belt, replaced the lid switch and the green led light on the motor blinks on and off steady... Don't know what else to try. Please help!!
sidfink43
#2 Posted : Thursday, October 1, 2015 4:06:56 PM(UTC)
sidfink43
Check the lid switch, not sure what is wrong with your model but that is a place to start if you are correctly resetting things and have no error codes.
whovian2015
#3 Posted : Thursday, October 1, 2015 6:58:27 PM(UTC)
whovian2015
I already replaced the lid switch. Didn't change anything.
sidfink43
#4 Posted : Friday, October 2, 2015 4:30:20 AM(UTC)
sidfink43
The problem with these GE models is that sometimes the diagnostics system does not work, and the only way to fix it is to start replacing parts. In your case it could be the motor, the mode shifter or the control unit. It could also be the wiring.
If you want to try replacing parts and order from this site you can return them. Sorry not to be of more help, it's GE that is the problem, not you or I.
whovian2015
#5 Posted : Friday, October 2, 2015 6:35:43 AM(UTC)
whovian2015
Thank you very much for your help! I really appreciate it! Wanted to make sure I wasn't missing something that might be simple.
sidfink43
#6 Posted : Friday, October 2, 2015 8:47:24 AM(UTC)
sidfink43
No you were not, there's no connection between GE and 'simple'.
GE washer won't spin or agitate. (Washer Repair)
by Eric9999 12/21/2015 10:19:03 AM(UTC)
GE washer won't spin or agitate (Washer Repair)
by unclejohnforever 2/27/2013 6:58:56 AM(UTC)
Ge washer won't spin or agitate (Washer Repair)
by Pwat300 12/3/2011 7:20:57 AM(UTC)
GE washer won't spin or agitate. Motor? Mode shifter? (Washer Repair)
by kzinti83 9/11/2011 4:57:09 PM(UTC)
GE Washer won't spin or agitate (Washer Repair)
by Soknows 5/24/2011 11:17:21 AM(UTC)
by mhilbeli 4/7/2011 4:38:33 PM(UTC)
by epows68 8/2/2009 11:19:54 AM(UTC)
ge washer won't spin or agitate (Washer Repair)
by agrimmer 2/19/2009 3:32:00 PM(UTC)
