bkw
#1 Posted : Tuesday, September 29, 2015 5:28:25 AM(UTC)
bkw
Hi,
This freezer was seldom used. Has not been turned on for about 1 yr.
When plugged in I hear a soft hum. No cooling what so ever. After a few minutes compressor is hot to touch. Thermostat turns unit off so I figured that was not the problem. Any trouble shooting tips or suggestions would be appreciated.
Bob
#2 Posted : Tuesday, September 29, 2015 6:07:40 AM(UTC)
Parts for Frigidaire FFC05M1CW0 Freezer - AppliancePartsPros.com
Here is the tech sheet
http://manuals.frigidaire.com/p...df/StCloud/216787900.pdf
First determine if the compressor is on. You can usually hear it but also should be able to feel it vibrating.
Sounds like it is trying to start but for some reason cannot.
Below is a good link on troubleshooting.
How To Fix a Refrigerator - Appliance Repair Guide - ACME HOW TO.com
Check out the compressor windings for continuity and that they are not grounded.
Note that this test can tell you if a compressor is bad it does not tell you that the compressor is good as it may have other internal problems.
I cannot tell if the start device is a relay or a PTC so testing it may not be possible. In this case you have to buy a new one and give it a try.
If it turns out that the compressor is shot, it will be an expensive repair and in most cases it makes more sense to put the dollars towards a new unit.
Frigidaire Freezer FPFU19F8WF4 - ice maker problem (Refrigerator & Freezer Repair)
by Eric8888 3/5/2024 11:02:19 AM(UTC)
Frigidaire Freezer Handle (Refrigerator & Freezer Repair)
by Guest 1/21/2024 12:46:23 PM(UTC)
Frigidaire freezer model mfu14m2gw0 (Refrigerator & Freezer Repair)
by HEAT8028 11/9/2022 6:58:32 PM(UTC)
Frigidaire Freezer - Does this dryer need to be replaced? (Refrigerator & Freezer Repair)
by jlchafin256 8/26/2022 8:17:22 AM(UTC)
Low side pressure reading - Frigidaire freezer (Refrigerator & Freezer Repair)
by jlchafin256 8/25/2022 4:37:58 AM(UTC)
Frigidaire freezer model number (Refrigerator & Freezer Repair)
by Elmer2020 7/18/2022 7:39:47 AM(UTC)
Frigidaire Freezer Door Pops When Opening - FFHB2750TS / Effortless Glide / Under French Doors (Refrigerator & Freezer Repair)
by daved31415 1/23/2021 12:44:44 PM(UTC)
Frigidaire freezer side not freezing, fridge side not very cold (Refrigerator & Freezer Repair)
by tenlbham 4/13/2019 1:48:16 PM(UTC)
Frigidaire Freezer error alarm (Refrigerator & Freezer Repair)
by mlkk993 10/26/2018 1:31:09 PM(UTC)
Frigidaire Freezer Only Top Coil Frozen (Refrigerator & Freezer Repair)
by mcmillbs 1/27/2018 8:45:38 AM(UTC)
Frigidaire Freezer warms then cools (Refrigerator & Freezer Repair)
by fridgeissues 10/5/2017 6:15:19 AM(UTC)
Frigidaire freezer HI TEMP (Refrigerator & Freezer Repair)
by Jellowe 5/24/2017 4:05:05 AM(UTC)
Frigidaire Freezer Compressor Hot (Refrigerator & Freezer Repair)
by swglenn 10/25/2015 5:32:56 AM(UTC)
How do you remove a Frigidaire Freezer contol board (Refrigerator & Freezer Repair)
by TxSmallFry 8/6/2015 4:49:11 PM(UTC)
Upright Frigidaire freezer not cooling right! (Refrigerator & Freezer Repair)
by rebeccagalligan 11/9/2014 11:41:41 AM(UTC)
