Ok the first thing I thought that was causing it to do this was the solenoids. I replaced them and still doing it. I moved on to the flame sensor. Replaced that also, still doing it. I then took apart the gas line thinking it might be partial plugged. Checked all out and its ok. What's causing it to light for a few seconds the go out?:confused:
Since you replaced the coil solenoids, and the flame sensor, have you checked to see if perhaps the gas inlet valve is closing after a few seconds?
