stephenh
#1 Posted : Tuesday, September 8, 2015 3:14:24 PM(UTC)
stephenh
our freezer stopped making ice i set it last night to "Max ice" but that did not make a difference.
nthing seems to be obstructing the moving parts.
I did replace the water filter recently.
the water dispenser is working fine.
stephenh
#2 Posted : Tuesday, September 8, 2015 3:23:22 PM(UTC)
stephenh
is there a reset button perhaps?
#3 Posted : Thursday, September 10, 2015 3:10:07 AM(UTC)
Parts for KSC24C8EYYO2 - AppliancePartsPros.com
See the attachments for a tech sheet and a ice maker troubleshooting guide.
First check the freezer temperature. It should be around 0degrees F.
Also if the fill tube is frozer your water vale may needc replacing.
Sometimes they do not shut off correctly letting a few drops of water run out after they shut off. This then freezer at the fill tube tip and overtime build up and clog the fill tube.
Guest (5)
kitchen aid not making ice (Microwave Repair)
by jmlodin 10/13/2009 4:35:59 PM(UTC)
