AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
GE Electric Dryer - Belt / slide fix, did I break something?
If I post a video clip of the squeaking, can you identify the issue?
I sort of doubt it. If you cannot find/localize it then odds are slim that i can. |
THIS FORUM IS DEAD!!!!!!! |
Originally Posted by: denman ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) I sort of doubt it. If you cannot find/localize it then odds are slim that i can. It definitely sounds like it's coming from the back. Should replacing the sleeve be worth trying before replacing the entire bearing kit
Probably worth a try. Especially since you are probably now a pro at taking this thing apart and reassembling it. |
Alright.
So, the first time I went to repair the dryer, before I did anything, I got shocked when touching the black outlet for the dryer connected to the wall. It scared me but I thought it was a fluke so I kept on using it to test the dryer.
Today, when I went to install the rear bearing kit, the outlet sparked when unplugging the dryer cord. I went ahead with the installation, reinstalled everything and went to plug in the cord again.
Nothing. The dryer has no lights, no power when turning it on.
I had my wife check the breaker and she flipped it on/off. I went to plug in the dryer again and it sparked again.
I called my landlord and we have an electrician coming. Does this sound like an issue with our apt? I would say so because it was iffy to begin with before any work was done to the dryer.
It kills me because I want to see if I fixed it. Hopefully it didn't blow anything within the dryer and it will work once things are fixed.
[COLOR="Blue"]Does this sound like an issue with our apt?[/COLOR] Yes the shock sounds like a wiring problem probably with the wall receptacle. Best to let the electrician deal with it. |
Originally Posted by: denman ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Does this sound like an issue with our apt? Yes the shock sounds like a wiring problem probably with the wall receptacle. Best to let the electrician deal with it. I had the electrician come while at work and he replaced the receptacle. Sadly, the dryer has no power and is still causing a spark. I have a feeling that it's not grounding properly with the new bearing kit. I installed it just as recommended in the video. Do you think that I knocked a wire lose inside or maybe it isn't completely secure? I am not sure what step to take next. I have to get it going because we absolutely need this dryer with a family of 4... two being young boys. Lots of dirty clothes that need addressing.
[COLOR="Blue"]Sadly, the dryer has no power and is still causing a spark.[/COLOR] What kind of spark? Is it a true electrical spark like 120 volts or is it just static electricity?
[COLOR="Blue"]I have a feeling that it's not grounding properly with the new bearing kit.[/COLOR] The grounding strap (item 515 in section 04) should be touching the metal end of the drum support shaft. If not bend it so it does.
[COLOR="Blue"]Do you think that I knocked a wire lose inside or maybe it isn't completely secure? [/COLOR] Sorry only you would know this. It is always a possibility.
I do not have access to GE wiring diagrams so cannot guide you on how to check the unit's start circuit with a meter. Perhaps start a new thread asking for help on getting the unit running and with luck someone will answer that has a wiring diagram. |
The story has a happy ending. I had pulled the wire lose in the back. Reattached it and the dryer is working great. Thanks for all the help.
Dryer Repair
