zoobteach
#1 Posted : 10 years ago
zoobteach
We have been having an issue with our washer for a month now. It will fill, agitate, rinse, but when it gets to the spin cycle, it will not spin. We have on occassion been able to get it to spin by removing all of the clothes inside, but that is hit or miss.
We used this post from a few years back to try to diagnose the problem. http://forum.appliancepartspros...nt-spin-dry-clothes.html
As instructed in that post, we unplugged the pump and tried the spin cycle. No noise except the timer.
Should our first step be to replace the timer? We stopped into a parts store a few minutes ago who insisted it is the lid switch. I don't want to permanently disconnect the lid switch if at all possible. Any way to test it without doing that?
My husband and I thank you in advance for any assistance! I'd really like to do laundry soon.
Edited to add: When the washer gets to the spin cycle, it will stay there until we manually shut it off. It is not completing the cycle on its own.
allen9258
#2 Posted : 10 years ago
allen9258
you will have to first check your lid switch with a multi-meter to see if it is bad before checking to see if maybe the clutch is bad i say that because of you having to sometimes pull clothes out to get it to spin. Hope that this is some help to you.
GE Washer not spinning (Washer Repair)
by atomicsynth 10 years ago
GE washer not spinning any cycle (Washer Repair)
by j409 11 years ago
GE Washer not Spinning (Washer Repair)
by jkomes 11 years ago
GE washer not spinning out all the water (Washer Repair)
by sbryant73 11 years ago
by Tigerhawk247 11 years ago
by jschust 11 years ago
GE washer not spinning (Washer Repair)
by dorlando 12 years ago
by jlbyrnes3 12 years ago
by JD0034 12 years ago
by mau397 13 years ago
GE Washer not spinning and smells strange (Washer Repair)
by greenfelt22 14 years ago
GE Washer not spinning. Bad motor or transmission? (Washer Repair)
by MrJosh 16 years ago
