Charlese
#1 Posted : Monday, August 17, 2015 11:15:49 AM(UTC)
Charlese
How do I do a self test of the washing machine?
fairbank56
#2 Posted : Monday, August 17, 2015 12:30:51 PM(UTC)
fairbank56
There's a tech sheet inside the cabinet of the washer. Here is a pdf copy of it.
Eric
File Attachment(s):
8567037.pdf (306kb) downloaded 8 time(s).
Charlese
#3 Posted : Monday, August 17, 2015 7:10:33 PM(UTC)
Charlese
Thanks for the info.
There was no tech sheet in the cabinet.
I can get the machine to fill with water and drain the water.
There are no codes showing.
Some of the green lights work.
Another site says to press and release for five seconds three times for the tests. Is there a difference on how to do the tests?
fairbank56
#4 Posted : Tuesday, August 18, 2015 7:30:49 AM(UTC)
fairbank56
It's clearly spelled out on the tech sheet that I provided as to how to enter diagnostic mode and perform the tests. That is the proper tech sheet for your model.
Eric
