taz_monster
#1 Posted : Thursday, August 6, 2015 4:11:45 AM(UTC)
taz_monster
I,
I need Help!!!
Yesterday I have to replace my motor in my dishwasher, find the part, change it and splash a gain in the machine, So now I have an other problem, I dont have anay heat on the element,
I have 13 oms for the element, I test the wiring to the control box, ok.
This morning I have pull out again my dishwasher just for checking if everithing is pluged, all ok.
What I miss!!!
:eek:
#2 Posted : Thursday, August 6, 2015 4:40:49 AM(UTC)
Here are your parts'
An AYW3 does not come up so the parts are for an AYW2.
They are probably the same.
Parts for Whirlpool WDF750SAYW2 / Dishwasher - AppliancePartsPros.com
See the attachment for your tech sheet.
Did you check the hi-limit thermostat (item 25 in section 05).?
It should be 0 ohms.
Also it might be a good idea to check the heater circuit at the control board. P4-3 to P4-4. This will check the heater, the hi-limit and the wiring.
Also check the thermistor resistance, see the tech sheet.
taz_monster
#3 Posted : Thursday, August 6, 2015 7:03:02 AM(UTC)
taz_monster
thanks
Yes, I check them o ohms,
I check on close circuit, Item by item, The element is 13 ohms, the termal sensor is ok.
I think it is the relay. So it is weld on board.
Tahnks
#4 Posted : Thursday, August 6, 2015 12:27:33 PM(UTC)
Yes it is soldered to the board.
It may be a bad relay but also could be the electronics that control the relay
WTW500DW1 wirlpool washer (General Talk)
by Ashley5791 2/13/2022 6:18:25 PM(UTC)
Wirlpool Centennial Washer (Washer Repair)
by 405husky 3/25/2020 8:51:06 AM(UTC)
Wirlpool 6ED22PKFXW01 (Refrigerator & Freezer Repair)
by Ady_E 1/3/2019 8:38:45 PM(UTC)
older Wirlpool dryer won't heat (Dryer Repair)
by automaticman 8/23/2014 4:48:43 PM(UTC)
wirlpool microwave (Microwave Repair)
by CFP 12/16/2013 5:28:13 PM(UTC)
wirlpool icemaker (Refrigerator & Freezer Repair)
by jimmy icemaker 1/30/2013 12:54:54 PM(UTC)
Wirlpool dishwasher upper arm not spinning (Dishwasher Repair)
by mogul397 12/13/2012 5:11:10 AM(UTC)
Wirlpool dishwasher will not stop cycling (Dishwasher Repair)
by dbarrett76 10/29/2012 12:02:26 PM(UTC)
wirlpool topload agitates but won't spin or pump motor hums (Washer Repair)
by curly33333 5/16/2012 6:51:35 AM(UTC)
Wirlpool Dishwasher Inlet Valve Voltage (Dishwasher Repair)
by nezoic 1/8/2012 10:05:22 AM(UTC)
my wirlpool washer wont spin (Washer Repair)
by cockroach 9/18/2011 8:26:39 PM(UTC)
Wirlpool Ultimate care II (Washer Repair)
by Peter R. 6/26/2011 1:07:57 PM(UTC)
Wirlpool Micorwave blows fuse when I press start magnetron or transformer (Oven Repair (including Ranges and Cooktops))
by wetpinkpants 10/2/2010 9:45:40 PM(UTC)
Need Wirlpool Mh3184xpy-1 tech sheet (Dishwasher Repair)
by wetpinkpants 9/30/2010 10:01:13 PM(UTC)
Wirlpool SM8280867 - Agitates but nothing else, won't drain (Washer Repair)
by clfry 9/27/2010 5:36:09 PM(UTC)
