Ice maker tray is not filling. Replaced the water valve kit today. Water dispenser on the door dispenses water. Switched the water valve electrical connection and pressed the door water dispenser button. Water pumped into the ice maker tray.
icemaker sends power to valve when temp at icemaker is < 6-8 deg F... needs to be cold in the freezer ... if it is cold enough, you could have a bad icemaker ... ( just make sure the tube in the wall of the freezer is not plugged closed with ice... ) remove plastic tube at back wall to go into the box toward the icemaker ... leave it in a bucket for several hours and see if you get water in the bucket.. if so, you have a clog in the tube in back wall of freezer, if not either not cold enough or bad icemaker ..
