k62254
#1 Posted : Friday, May 29, 2015 1:10:18 PM(UTC)
k62254
Hi, I have a whirlpool resource duet front loading dryer. My safety control lock seems to be locked. I hold it for 3 sec and nothing happens, however if I slightly hit it the light goes off and then I can slight hit it and it comes back on, but its still in lock mode. When I turn the dryer off and try to put it in lock mode it works and I can unlock it.. when I try and start my dyer is just beeps. I have replaced the control panel boad and main control board and neither fixes the problem. The theremafuse has been replaced as well. any idea before I have to buy a new dryer
Simon / APP Team
#2 Posted : Friday, May 29, 2015 2:08:01 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi, k62254.
Did you try to replace the console assembly, not just the control board inside it?
The console assembly Part number: AP4500422
Thank you. Keep us posted.
Best,
Simon.
k62254
#3 Posted : Friday, May 29, 2015 2:14:03 PM(UTC)
k62254
No I did not try that part because it didn't seem like that would be the issue because it's just plastic I guess I'm wrong on that? Could just that plastic part really be the issue and not the control panel behind it
Simon / APP Team
#4 Posted : Friday, May 29, 2015 2:29:22 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
In your case we need to check all the options. Also, I would check all harness wires and connectors between those two controls.
Best,
Simon.
k62254
#5 Posted : Friday, May 29, 2015 2:50:30 PM(UTC)
k62254
Would it make a difference if I ordered the electronic board with a new plastic cover? Or can I order just the plastic cover and attach my electronic board to it?
Simon / APP Team
#6 Posted : Friday, May 29, 2015 3:52:29 PM(UTC)
Simon / APP Team
Groups: APP Team
i don't see the cover being sold by itself. And again, I'm stressing out that the wire harness should be checked.
Best,
Simon.
Guest (5)
