derfla77
#1 Posted : Friday, May 29, 2015 9:19:57 AM(UTC)
derfla77
Hello All,
I have a Whirlpool side by side fridge. The ice maker is making very little ice and I hear the water running occasionally to make more. Problem is I also noticed water leaking out somewhere on the left side of the fridge/freezer.
I turned off the ice maker and the leak appears to have stopped (water running to make ice has stopped too)
Water dispenses fine out of the water dispenser.
I also installed a new filter so I'm not sure if a clogged filter is the culprit.
Any idea what may be the cause and what to repair? Thank you in advance!
Simon / APP Team
#2 Posted : Friday, May 29, 2015 11:27:49 AM(UTC)
Simon / APP Team
Groups: APP Team
Hello.
Are the cubes normal size, not hollow? Also, check the model number, please the one you provided is not coming up.
Best,
Simon.
