I have a 36" KitchenAid Built-in Refrigerator Model # KSSC42QMS01.
The Ice-maker has worked fine for years but yesterday it stopped producing ice.
I checked on the forum and after reading various posts checked the optics: I get 2 flashed followed by one second and whe I close the flapper the led is solid which seems to eliminate the optics.
I then removed the water filter, and rechecked the led: no light. I thought I found the problem (I have not changed the filter since a long time).
This morning there was some ice in the bin (2 or 3 batches), and the led is blinking one more time. Checked again closing the flapper, and I get a solid light.
Any idea what is going on?
Thanks for your help
The boards are checking good. You need to check the temp in the freezer. It should be 0 to 5° for proper icemaker operation.
Thanks for the quick feedback.
Temperature is below 0, I actually went to minus 3 and waited for 24 hrs and I have the same blinking led that goes solid when I close the flapper.
An ice batch has been made but not dispensed, and the water pressure at the water dispenser is fine.
Any idea of what to look for?
Thanks!
