tilegods
#1 Posted : Friday, May 1, 2015 4:15:19 AM(UTC)
tilegods
Where is the pressure sensor? I have replaced both control boards and still receive this error. I can see the pressure switch. All other functions are working while running through diagnostics mode. Any help is appreciated.
sidfink43
#2 Posted : Saturday, May 2, 2015 11:17:41 AM(UTC)
sidfink43
Here is a link to the service manual for a model similar to yours.
http://www.emaservicetips.com/p...sher_5995536298_3-09.pdf
Good luck, hope this helps.
tilegods
#3 Posted : Saturday, May 2, 2015 4:40:37 PM(UTC)
tilegods
Thanks for the manual! I will replace the pressure switch next, as the wiring shows continuity! It was not clear to me that the pressure sensor was part of the pressure switch! Thanks again! 'Will update after part arrives!
