smkelley
#1 Posted : Friday, April 24, 2015 1:51:07 PM(UTC)
smkelley
I have a Frigidaire Affinity front load washer (has the O not U imprint on the side panel) that recently quite working mid cycle (full of water). The machine is making a buzzing noise from the lower right corner and displays "SENSING" on the screen. It wont drain, start a new cycle, etc... just keeps "sensing" When it was under warranty it made a similar buzzing noise when the door wouldn't latch fully and the technician replaced the door latch assembly and door strike. I recently purchased both and replaced them however the "sensing" and buzzing continues. Ideas?
sidfink43
#2 Posted : Sunday, April 26, 2015 2:36:55 PM(UTC)
sidfink43
Look inside the lower service panel for tech notes that will tell you how to put it into a diagnostic mode and generate error codes.
The door lock assembly fails regularly on Frigidaire front loaders, so check that again. Also check the main control unit and the motor/speed control unit using the tech notes.
smkelley
#3 Posted : Sunday, April 26, 2015 2:44:59 PM(UTC)
smkelley
Thank you. I didn't find the tech sheet but got underneath the unit ( it was stacked so I couldn't pull front or back panels off) and found the catch filter in the rubber boot between the drum and pump was full of coins and a bra underwire had slipped through & lodged into the impeller. Problem solved ! Thank you for the input. I'm going to keep the 2nd latch assembly knowing I've already had to replace it once.
sidfink43
#4 Posted : Sunday, April 26, 2015 2:52:04 PM(UTC)
sidfink43
Ok good. I forgot to mention that checking the drain pump is the first thing to do. Glad you got it fixed and thanks for the update.
