Jokald
#1 Posted : Friday, April 24, 2015 2:58:46 PM(UTC)
Jokald
I just finished replacing the drain pump and now when I start a cycle the drain pump starts running and nothing else happens. Not a happy DIY'er.
sidfink43
#2 Posted : Sunday, April 26, 2015 2:41:46 PM(UTC)
sidfink43
See what happens if you disconnect the new pump and try to operate the machine. It may be that the new pump is bad and causing the problem or it may be that the control unit is bad in which case its prohibitive cost means replacing the machine is the better option.
Jokald
#3 Posted : Monday, April 27, 2015 4:43:05 AM(UTC)
Jokald
It did end up being the control unit. There were a couple of diodes that looked like they were fried.
sidfink43
#4 Posted : Monday, April 27, 2015 5:44:04 AM(UTC)
sidfink43
Well sorry to hear that but glad you found the problem and thanks for the update.
