2 Pages<12
Snakeclan
#11 Posted : Sunday, December 16, 2007 8:24:31 PM(UTC)
Snakeclan
should I be seeing your response right away or do I need to pull up my e-mail each time?
Snakeclan
#12 Posted : Sunday, December 16, 2007 8:25:11 PM(UTC)
Snakeclan
never mind your posting came up
Snakeclan
#13 Posted : Sunday, December 16, 2007 8:26:57 PM(UTC)
Snakeclan
everything looks fine on the wire
kawfeeman
#14 Posted : Sunday, December 16, 2007 8:39:25 PM(UTC)
kawfeeman
bake element has a yellow wire on one side... follow it to where it terminates at ( should be at the control or ERC ... ) ... with the control powered on but no cooking programs chosen, check voltage out of ERC to GND.. (probably 110vac ) ... since you have 110vac being supplied all the time to one side of each element, then the ERC relay must be 'welded' closed...
Snakeclan
#15 Posted : Sunday, December 16, 2007 8:55:23 PM(UTC)
Snakeclan
okay I have done that and it seems to be welded shut
kawfeeman
#16 Posted : Sunday, December 16, 2007 9:01:14 PM(UTC)
kawfeeman
(disconnect that yellow wire to element and electrical tape it well ) ....this way you can leave power to range on and use top burners... order the clock / erc and replace ...
Snakeclan
#17 Posted : Sunday, December 16, 2007 9:02:58 PM(UTC)
Snakeclan
Thanks for the help. I will get that going hope you have one in stock
kawfeeman
#18 Posted : Sunday, December 16, 2007 9:06:39 PM(UTC)
kawfeeman
let me know if they do or not ... or if you need the part #
Guest (7)
2 Pages<12
