I cannot find a specific video or instructions for this particular dryer model. The dryer is making a horrendous squeaking noise and I want to check the rollers and other components. I cannot seem to find out how to get the front panel off. Doesn't look like it is a rear entry dryer- way too many screws and flanges.
Thank you for any advice you may have.
Joined: 10/16/2012(UTC) Views messages in topic : 3,806
There are two clips at the top edge of the toe panel. Use a putty knife to release them. To open top panel, use putty knife under each end of the control panel to release those clips. Rotate control panel back for access to two screws holding top panel. Remove those two screws and then pull top panel forward and lift from cabinet. Now you have access to the screws that hold the rest of the front panel.
Eric
