davidlswenson
#1 Posted : Tuesday, December 30, 2014 9:43:21 AM(UTC)
davidlswenson
Dryer quit heating but runs.
Thermal cutoff was open, so I replaced it and the high limit thermostat.
Worked great for a few minutes--then quit heating again. Thermal cutoff is open again.
Have checked the thermal fuse--has continuity, 240 v coming in, heating element has continuity.
Did I get a bad part? Any ideas?
Thanks!
#2 Posted : Wednesday, December 31, 2014 4:45:02 AM(UTC)
[COLOR="Blue"]Did I get a bad part?[/COLOR]
I doubt it.
When you replaced the cut-off did you check anything else in the heater circuit?
If not I would start by checking to see if the element is grounded with a meter.
If the heater element is grounded it can run too hot. This can blow the cutoff right away as even the hi-limit thermostat cannot regulate the temperature.
davidlswenson
#3 Posted : Wednesday, December 31, 2014 6:27:24 AM(UTC)
davidlswenson
I doubt it.
I will check it --thanks very much! I am also going to have to crawl under the house and make sure the vent is not getting clogged. I disconnected the vent hose, replaced the cut off and both thermostats and it is running now ok.
Thanks again.
dls
handygirl67
#4 Posted : Thursday, March 12, 2015 1:22:38 PM(UTC)
handygirl67
How do you check if the heater element is grounded? I have the same problem.
#5 Posted : Monday, March 16, 2015 3:33:18 AM(UTC)
Unplug the unit
Unplug both wires at the heater element.
Measure across the element, should be in the 8 to 12 ohm range.
Then measure from each side of the element to it's case, both should be infinite ohms
sowens004@woh.rr.com
#6 Posted : Tuesday, March 17, 2015 3:05:37 AM(UTC)
Unplug the unit
If the heater element is grounded then what do you don't? Replace it?
#7 Posted : Wednesday, March 18, 2015 2:01:38 AM(UTC)
Yes, you replace it.
