I have a WHDSR315 GE 15 cycle/3 speed toploader doesn't agitate or spin. Actually it will - unless there is any weight in the drum (ie clothes or water).
I pulled the front and I have verified the magnetic door switch and water level switches are working mechanically. I have not yet checked them for electrical (ie continuity with the door shut).
It pumps out fine. The motor never spins with weight in the drum, but it gets very hot. I can turn the belt by hand, but it doesn't turn the agitator.
I would greatly appreciate any help in troubleshooting this.
You would really need to check voltages at the motor connector while motor is trying to run in order to determine if the problem is the motor or a voltage drop to the motor due to faulty timer or wiring/connections. It could also be a faulty motor capacitor or failing lid switch. It may also be the transmission if it is binding and putting too much load on the motor. Too many things in the mix here to try and walk you through it all. You might just try parts swapping. Anything purchased from APP can be returned if it doesn't fix the problem.
Eric
As ever I appreciate the help. I was hoping for a obvious problem with a clear fix. That is apparently not the case here.
Do you have a recommendation as to what parts to swap to begin the process? I am reasonably capable with a multimeter.
Tom
Well, I'm a troubleshooter, not a parts swapper. Hard for me to tell someone to swap parts til it's fixed. It's hard to say without knowing if the problem is electrical or mechanical. For you, I would say get the timer, capacitor and lid switch and go from there. You can return whatever you don't need.
Eric
Originally Posted by: fairbank56 ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Well, I'm a troubleshooter, not a parts swapper. Hard for me to tell someone to swap parts til it's fixed. It's hard to say without knowing if the problem is electrical or mechanical. For you, I would say get the timer, capacitor and lid switch and go from there. You can return whatever you don't need.
Eric Thanks Eric. So far I have swapped capacitor, ruled out lid switch, and tried a new timer. The new timer has been quite problematic. I am not sure I have the right one. With the new one in, it will only fill and drain, never advance the time, nor do any actual washing. Just fill, drain endlessly. The electrical pinouts are the same, but the part numbers are different: The original has these part numbers": 6249B GE 17505 100P008 M298 Kingston 71291 - A04438 The new one has this part number: 175D4232P024 011-64457-01 M620 -P024 Suggestions or help? Thank you. Tom
