paulgbernard
#1 Posted : 10 years ago
paulgbernard
Hello:
The other day our oven just decided to quit unexpectedly. It was working fine the day before.
I tore it apart and checked all three elements (broil, bottom, and convection). They all looked fine and were within resistance specifications (around 26 ohms). I also tested the safety oven sensor and it also tested within specifications (around 1070 ohms).
I inspected all the wiring and there were no shorts or burns. The wall receptacle voltage was also fine. There are no error codes listed on the display.
When I turn on the oven, it clicks on as always, begins a preheat cycle, and the convention fan starts up as normal. Everything is works perfectly as expected, except the elements do not heat up.
I am at a complete loss. Is there a fuse somewhere which would disable the heating elements? The breakers above the control panel have not been tripped.
Help please!
#2 Posted : 10 years ago
Parts for Whirlpool GLP85900 Range - AppliancePartsPros.com
I am assuming that the stove top elements work OK.
There is not a fuse or breaker for just the stove elements.
Does it stay in preheat or does it show that the oven is ready?
If it shows that it ios ready it could be an oven sensor.
If it stays in preheat then I would say that it is a control board problem.
It looks like the control board is obsolete but there are companies that repair obsolete boards just Google "appliance timer repair"
File Attachment(s):
GLP85900.pdf (171kb) downloaded 6 time(s).
paulgbernard
#3 Posted : 10 years ago
paulgbernard
Hi:
Thanks for the prompt reply.
Yes, the stove elements work just fine. The oven also goes through the preheat cycle and beeps like always to indicate when it is ready, but there is no heat. Everything works as it always has, just no heat from the oven elements.
I did not get any error messages so I'm assuming that the board is not the problem.
I did test the resistance on the sensor and it was within specifications.
Although the sensor did test out fine, could it still be the culprit?
Thanks again,
Paul Bernard
#4 Posted : 10 years ago
[COLOR="Blue"]Although the sensor did test out fine, could it still be the culprit?[/COLOR]
I doubt it but it may be worth it to re-test it.
paulgbernard
#5 Posted : 10 years ago
paulgbernard
Denman:
Did a few more tests using the wiring diagram I found.
I tested the voltage to the leads going into the board (P2-4 and P2-1). Both read about 37 V when the oven was turned on or off. I'm assuming these are the power leads to each of the element. If this is the case, should it not be reading a much higher voltage to heat up the elements? Does this rule out the temperature sensor and point more towards a control board problem?
Thanks again for your help. I think we're closing on to a solution.
Paul Bernard
paulgbernard
#6 Posted : 10 years ago
paulgbernard
Sorry Denman, correction to my last post.
When I turn the convection bake on I see a jump up to about 180 V for a second, then drops to zero. This is testing the P6 and P2-4 leads (bake element).
Sensor?
#7 Posted : 10 years ago
Since the unit shows it is ready and the oven sensor is OK it points to a bad control board re: it is not interpreting the oven sensor resistance correctly.
Gas Oven not heating up (Oven Repair (including Ranges and Cooktops))
by Guest about a year ago
upper oven not heating up to desired temp. it's off by about 50 degrees (Oven Repair (including Ranges and Cooktops))
by Guest 2 years ago
Oven not heating up and gas smell in house (Oven Repair (including Ranges and Cooktops))
by DJKNY71 8 years ago
by gplundell@msn.com 10 years ago
Oven NOT heating up at all (Oven Repair (including Ranges and Cooktops))
by bkevans88 10 years ago
Oven not heating up right. (Oven Repair (including Ranges and Cooktops))
by clueless78 10 years ago
Oven not heating up after self cleaning (Oven Repair (including Ranges and Cooktops))
by JD40 11 years ago
Oven not heating up (Microwave Repair)
by coldoc89 12 years ago
oven not heating up (Oven Repair (including Ranges and Cooktops))
by vwforonda 13 years ago
GE Gas Oven not heating up correctly (Oven Repair (including Ranges and Cooktops))
by ichengsd 13 years ago
convection oven not heating up to correct temperature (Oven Repair (including Ranges and Cooktops))
by cecelo 13 years ago
by cren722 13 years ago
oven not heating up to temperature (Oven Repair (including Ranges and Cooktops))
by buhr 13 years ago
by doette-56 14 years ago
by rpeters23 14 years ago
