3 Pages<123>
mthomtech
#11 Posted : Friday, May 15, 2009 12:02:15 AM(UTC)
mthomtech
I have a similar problem as described here, but found something different.
Our unit has been on and off for awhile, but eventually went off for good. After a breaker on/off, the oven would make some noise (no control panel lights at all) but I could turn the oven on. But after about a minute or so, 4 beeps and back to nothing.
I'd read about the ribbon connection on the control panel, so I opened up the control panel and adjusted the connection ... no change.
Then I noticed something ... the Transformer located above the upper oven (behind the control panel) is burned out. The two red discs labeled V1 and V2 are burned to a crisp.
Now, I found the part ... but my question is what would be the cause of this ... and how do I know if anything else it wrong.
Thanks!
#12 Posted : Friday, May 15, 2009 6:17:42 AM(UTC)
First is your Model the same as the original post?
The board you describe is a spike suppressor, it is supposed to stop voltage spikes on the line from getting onto the control board and blowing electronic components.
Also by the sound of it your transformer has overheated and needs replacing.
I am leery of the wiring diagram as it does not match the parts exactly.
It is hard to say what took the parts out, the only thing I can think of is a massive voltage spike or the voltage being much higher than it should. It could be that there is a problem with the house wiring and it blew the spike suppressor first and the blew the transformer later.
Odds are also high that the control board is toast.
This may be one where it would be best to get a pro in, unless you have some electrical or electronic experience and a meter.
mthomtech
#13 Posted : Friday, May 15, 2009 8:49:59 AM(UTC)
mthomtech
Thanks for the quick reply.
My model is the RBD305PRB00.
Here's a diagram that I found (the part in this diagram is #20). You're right, it is the suppressor, I was reading the wrong part when I said the transformer.
Replacement parts for WHIRLPOOL RBD305PRB00 | AppliancePartsPros.com[URL="http://www.********************.com/ModelFrames.aspx?ModelID=760733&ModelNum=RBD305PRB00&mfgModelNum=&ManufactureID=3&Selected=HMKE6OUG&Position=4&mfg=Whirlpool&Type=&Mark=4"][/URL]
I wouldn't doubt that something was maybe wired wrong since this was installed in a new construction.
I have hope that the control board is fine, because it would come on randomly for a while, then fade away eventually.
Maybe it is only the suppressor that is bad. I guess it could be from lightning. I'm considering pulling the oven out, checking the connections to the house wiring and replacing the suppressor, for $50. But maybe it's better to get a pro to look at it.
#14 Posted : Friday, May 15, 2009 11:21:58 AM(UTC)
That is a different kettle of fish, if only the suppressor is burned.
I would disconnect the spike suppressor and then try powering the unit up without it.
Perhaps it is the culprit.
In any case you have nothing to loose.
If the unit comes up and runs then all you have to do is order and replace the suppressor ASAP.
mthomtech
#15 Posted : Friday, May 15, 2009 11:29:54 AM(UTC)
mthomtech
If I disconnect the spike suppressor how do I connect all the wires that connect via the spike suppressor bolts? Just keep the together and insulate each group with electrical tape for the test?
#16 Posted : Friday, May 15, 2009 5:32:09 PM(UTC)
Could do it that way, but I thought the spike control was bolted to the terminal strip and then the wires attached to the terminal strip bolts.
mthomtech
#17 Posted : Monday, May 18, 2009 5:00:04 PM(UTC)
mthomtech
It may be ... I'll take a closer look and try it out.
mthomtech
#18 Posted : Tuesday, May 19, 2009 9:15:19 PM(UTC)
mthomtech
You were right, denman. I took out the spike suppressor and reattached the wires to the terminal strip. Unfortunately, upon powering back on, the same results. It attempts to power up, but there is no LCD panel lights, and within a minute or so, I get a series of five beeps (short - long - short - short - short). I get that same sequence whenever I press the start button.
I checked the connection to the house wiring and it looked OK, so I'm guessing that lightning was the culprit.
I also took off the touch panel to get a better look at the control board, but I couldn't see any really obvious damage to it. The only thing I noticed was a black circle in the upper right corner of the LCD screen (which looks like where a LCD lamp is). I can't tell if that spot is normal or if it's an indication of something.
The suppressor is definitely bad, but it looks like the control panel (or something else) is also bad.
Now, I'm thinking I may be in the cost realm to get a pro to look at it. I'd hate to spring for a control board if that's not the only issue.
Thoughts?
#19 Posted : Wednesday, May 20, 2009 3:35:28 AM(UTC)
Here is the tech sheet
https://www.servicematters.com/d...0Sheet%20-%208302068.pdf
It may be time for a pro.
You should check the voltage output of the transformer.
I do not know what the output should be, it may be marked on the transformer. If you cannot determine what it should be, then it should be checked with the transformer connected to the board and then disconnected to see if the board is pulling down it's output.
If I was doing this I would disconnect the various plugs going to the board so all that is left is the board and transformer and see if it comes alive.
If it does then components have to be checked to find which one is causing the problem.
If it is still dead I would still check components just to be sure one of them does not take out the new board.
The above is probably overly cautious but I am a firm believer in safe instead of sorry. Odds are high that it is just your control board but not 100%.
Also I do not know what your series of beeps mean.
I am off to the lake for a couple days so I am going to ask for help from others in the tech section. With luck one of them will have additional suggestions and/or know how to interpret you beeps.
#20 Posted : Wednesday, May 20, 2009 12:11:03 PM(UTC)
Just to add my 2 cents...
I believe the main purpose of this suppressor is to protect radios and TVs from Radio Frequency Interference. This device is not very important because it does not have any safety functions and does not affect the oven performance. You can replace it or use the oven without this part - up to you.
The major problem is that the oven control does not work as it suppose to, and the correction I believe is to replace the control board and the low voltage transformer. These parts are not too difficult to replace yourself and you can save a lot on labor charge and parts mark up (enough to by a new membrane switch which I do not think you'll need).
- The part number for the control board is AP3873768
- The part number for the low voltage transformer is AP3968801
Guest (13)
3 Pages<123>
