I have an LG front load washer that died in the spin cycle, it wouldn't turn back on I checked breakers and none had blown, took the multimeter to it and found power coming in as far as the PCB Main control panel (LG EBR38163357) but nothing from there. after I replaced it, it went through two cycles and blew it again. What could be doing this? Is it a common problem? Is it possible I got that unlucky it seems there must be something frying it from elsewhere in the machine. Help PLEASE these things are not cheap. Thanks Tony
I know this is an old post, but wondering if the problem continued? I have an LG Drying doing the same thing. worked for two years then just died, new main board (EBR76519513). new board lasted 5 months, next one lasted 30 days.
