laundry1
#1 Posted : Tuesday, January 20, 2015 11:46:37 AM(UTC)
laundry1
The dryer will not start. Setting the mode switch to all positions and turning the on knob on results in nothing. No sounds nothing. The light in the drum works and the breaker has not been tripped. The vent is clear. Suspect the on off switch or the timer being bad at this junkture. I guess I need some guidance as to where to look next. Thank you
laundry1
#2 Posted : Tuesday, January 20, 2015 11:51:45 AM(UTC)
laundry1
anyone there?
#3 Posted : Wednesday, January 21, 2015 12:41:06 AM(UTC)
Parts for Estate TEDS780JQ0 Dryer - AppliancePartsPros.com
The part at the top of the list would be the thermal fuse (item 7 in section 03).
Unplug the unit and check the fuse with a meter, should be 0 ohms.
If blown be sure to check/clean your vent system as that is the most common cause of it blowing.
Would also be a good idea to check/clean the blower wheel.
File Attachment(s):
TEDS780.pdf (216kb) downloaded 4 time(s).
Whirlpool Dryer Wont Start! Please HELP!! (Dryer Repair)
by KatharineF 11/11/2013 12:38:08 PM(UTC)
whirlpool dryer wont start (Dryer Repair)
by klv 7/30/2013 3:27:52 PM(UTC)
My Whirlpool dryer wont start (Dryer Repair)
by usmcmom09 2/15/2012 4:22:54 PM(UTC)
Roper by Whirlpool Dryer Wont Start (Dryer Repair)
by cjduke 7/30/2011 12:23:39 PM(UTC)
Electric Whirlpool dryer wont start (Dryer Repair)
by drew85205 11/5/2009 1:14:53 PM(UTC)
by mercedes1 9/17/2009 9:14:41 AM(UTC)
Whirlpool Dryer wont start (Dryer Repair)
by tinkv192 6/4/2009 5:29:16 AM(UTC)
whirlpool dryer wont start in dry miser mode (Dryer Repair)
by tequilla 6/10/2008 3:06:03 PM(UTC)
